 100% scratch!!!
100% scratch!!! Empty
MessageSujet: 100% scratch!!!   100% scratch!!! EmptyVen 25 Oct - 11:08
OK le modèle est ingrat, mais le boulot est superbe!!! Shocked
The Work of Bruce Owen
Virtue RSX
Bruce Owen's Virtue RSX. Bruce's fabulous bit of unexcelled craftsmanship was under construction for about a decade. Bruce competed at the just completed Nineteenth GSL International Model Car Championship (www.GSLChampionship.org) where it won many top awards, including the much-desired Best of Show Master Award. The staff here at the Custom Clinic is pleased to prevent a comprehensive set of photographs of Bruce's work, from inception through completion, along with other documents from Bruce's workshop. Reportedly, Bruce has another killer project underway, and we'll report on it as soon as information becomes available. We, at the Custom Clinic, thank Bruce for supplying the materials seen here. Also, check out Mark S. Gustavson's upcoming full feature on this model in Scale Auto.
Bruce here gives a background narrative on why he built this model, and named it as he did. This text is in the form of a letter to GSL founder, Mark S. Gustavson
Bruce provided a comprehensive three-ring binder to the judges and participants at GSL-XIX. Here is the letter he provided to GSL-XIX:
Bruce has also submitted an exceptionally comprehensive list of photos of the construction of his Virtue RSX. Check out these photos and marvel at the craftsmanship:
Here the basic chassis design which was created before any actual construction started:
100% scratch!!! Vir0013
Here's where the model was built:
100% scratch!!! Vir0015
100% scratch!!! Vir016
Here are the parts required to build the model just before chrome plating and painting. Note the resin-cast body in the background.
100% scratch!!! Vir0017
The scratchbuilt brass frame, built to the specifications he had previously crafted, is a work of art.
100% scratch!!! Vir0021
The scratchbuilt wheels are typical of the quality of the work in this model.
100% scratch!!! Vir0022
Bruce even created specialty Michigan manufacturer license plates. Check these out:
100% scratch!!! Vir0023
The windshield frame was hand-crafted from copper and then chrome plated.
100% scratch!!! Vir0030
Pulled from a mold, Bruce's model suggests at future details.
100% scratch!!! Vir0032
Here in an array of the body molds and masters that lead to the finished model.
100% scratch!!! Vir0033
Check out all the many molds that were required to produce the major parts for this model.
100% scratch!!! Vir0051
The disk brakes, and other parts, were machined and then chrome plated.
100% scratch!!! Vir0055
Bruce wisely test fitted everything before blowing the model apart and painting/plating the parts. Mark S. Gustavson also advocated this approach in DreamTruck2 feature in Car Modeler 2003.
100% scratch!!! Vir0062
At this point, all of the parts have been fitted to the frame, body and interior allowing Bruce to check for fit and clearances.
100% scratch!!! Vir0073
The body was primed . . .
100% scratch!!! Vir0075
and then the body was painted . . .
100% scratch!!! Vir0025
100% scratch!!! Vir0027
When the parts had been fitted to the frame to check for clearances and so forth, Bruce started to paint the model. The frame is painted the same bright red solid color as the rest of the model.
100% scratch!!! Vir077
With the frame paint dried, Bruce started to install the pre-fit suspension components.
100% scratch!!! Vir079
As parts are installed, the result if breathtaking .
The assembly process must have been challenging, but look at the results. . .
100% scratch!!! Vir103
Up on its wheels, tire, the level of craftsmanship begins to look great . . .
Please enjoy the following essay on final assembly and the completed model:
100% scratch!!! Vir106
100% scratch!!! Vir114
100% scratch!!! Vir180
MessageSujet: Re: 100% scratch!!!   100% scratch!!! EmptyVen 25 Oct - 12:38
T'as raison monster : caisse de merde, mais résultat worthy worthy worthy
MessageSujet: Re: 100% scratch!!!   100% scratch!!! EmptyVen 25 Oct - 13:47
Mais vraiment caisse de merde comme tu dis... Faudrait pas mettre la carrosserie dessus pour bien faire. Ils sont fous ces gens... Smile
MessageSujet: Re: 100% scratch!!!   100% scratch!!! EmptyVen 25 Oct - 14:21
+1, du grand savoir faire mis au service du grand n'importe quoi beaurk! beaurk!  mais chacun ses gouts epaule
MessageSujet: Re: 100% scratch!!!   100% scratch!!! EmptyVen 25 Oct - 14:57
Mais ca existe comme bagnole ou c'est le gars qui l'a inventée? genre proto...
MessageSujet: Re: 100% scratch!!!   100% scratch!!! EmptyVen 25 Oct - 15:18
je pense qu'il l'a inventée...
le genre de gars qui dépasse son niveau de compétence.
maquettiste surdoué, piètre designer epaule
MessageSujet: Re: 100% scratch!!!   100% scratch!!! EmptyVen 25 Oct - 15:22
Piètre désigner effectivement, ou alors des gros goûts de chiottes comme on en fait plus... Même s'il avait copié un modèle existant, a tous les coups il aurait choisi un truc de merde Smile
Mais ca n'enlève rien à la qualité de sa maquette...
Clouet
Clouet
MessageSujet: Re: 100% scratch!!!   100% scratch!!! EmptyVen 25 Oct - 16:36
salut
super travail sur le chassis , et le moteur
le reste ................................ c est un mélange entre une limace ridée et une vector:ahahah: ahahah ahahah
MessageSujet: Re: 100% scratch!!!   100% scratch!!! EmptyVen 25 Oct - 16:39
Clouet a écrit:
vector
ta-ta-taaaa, la vector, dans son genre elle est quasi parfaite drunken
MessageSujet: Re: 100% scratch!!!   100% scratch!!! EmptyVen 25 Oct - 17:11
Autant de compétences pour, au final, faire un truc aussi laid ! C'est gaché !!! epaule
MessageSujet: Re: 100% scratch!!!   100% scratch!!! EmptyVen 25 Oct - 17:45
Je vous suis sûr ce coup là.. c'est   beaurk!    mais le taff est   Shocked  !
MessageSujet: Re: 100% scratch!!!   100% scratch!!! EmptyVen 25 Oct - 20:35
j'ai franchement du mal a comprendre comment peut ont faire un travail aussi précis et fin , et faire un bouse au final :intero: :intero: ont dirais un conept car des années 80 dent mais en + moche encore dent
MessageSujet: Re: 100% scratch!!!   100% scratch!!! EmptyVen 25 Oct - 20:37
Un peu comme les mecs qui se font chier pour faire une jolie Gremlin Smile
Oh oui la Vector je connaissais pas c'est absolument énorme comme voiture... les anciennes sont incroyable avec ce petit coté cosmos 1999 ! excellent !
MessageSujet: Re: 100% scratch!!!   100% scratch!!! EmptyVen 25 Oct - 20:40
bein franchement je préfère ta gremrino ou gremlino , je sait plus , a cette réa , et de loin oui
MessageSujet: Re: 100% scratch!!!   100% scratch!!! EmptyVen 25 Oct - 20:41
Il aurait du la peindre en starsky et hutch... avec cette peinture, on peut faire ce qu'on veut Smile
MessageSujet: Re: 100% scratch!!!   100% scratch!!! EmptyVen 25 Oct - 20:45
nan je suis même pas sur , ça aurais encore aggravé les choses dent
MessageSujet: Re: 100% scratch!!!   100% scratch!!! EmptyLun 28 Oct - 1:43
C'est dommage ! Moi j'aurais pas mis la carrosserie ! beaurk!
COBRA JET
COBRA JET
MessageSujet: Re: 100% scratch!!!   100% scratch!!! EmptyDim 3 Nov - 14:41
entièrement d'accord avec Speedicor tant qu'il n'y avait que le chassis et le moteur ça allait
MessageSujet: Re: 100% scratch!!!   100% scratch!!! EmptyDim 3 Nov - 15:11
Comme tout le monde travail excélent, mais carroserie de merde de pigeon!!
100% scratch!!!
