 1957 Baja Bug Gunze/Kyosho kitbash (FINI)
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Ven 14 Nov - 21:28
Terrorist Man is back
How do you do that?
Chromecop
Chromecop
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Ven 14 Nov - 21:55
How do you do that?
First I drill 2 small holes. Then I just cut a score between the holes, Clean the score up with a Nail-file and finally I take a short piece of Evergreen halfround rod that fits in the score and glue it in Place.
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Ven 14 Nov - 23:00
Wow! Great built!
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Lun 17 Nov - 13:23
good job!!
Chromecop
Chromecop
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Ven 21 Nov - 22:42
Made a Little progress today. Not much but still... Embarassed
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Sam 22 Nov - 9:12
good work thumbsup , i can't do that , but it's normal for you you're terroriste in your head Wink
Chromecop
Chromecop
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Mer 26 Nov - 18:59
Now, there's a hole in the roof and I've widened the chassie a Little just behind the front Wheels.
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Mer 26 Nov - 20:12
It's a good idea to make it an open roof thumbsup
Chromecop
Chromecop
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Sam 29 Nov - 12:56
This week I only had one day off work, so I really didn't have much spare time for modelling. However, I did manage to get a couple of hours in the mancave and here's the result. I've started scratchbuilding a Porsche Fan shroud for the engine, partly from a Fujimi Porsche and some other scrap parts (from a 1/8 scale Honda 750 cc bike!!!!)
As I didn't like the stock "firewall" i cut it off, and replaced it with a somewhat modified piece from another VW-kit:
I also found a simple roll-bar in my stash:
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Sam 29 Nov - 12:57
Great work ! Continue, this Baja will look fabulous !
Chromecop
Chromecop
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Sam 29 Nov - 13:11
Thanks!!! I'll continue as soon as I get home from work, on tuesday night that is.... santé!
I'm also considering building a turbo for the engine, and of course it'll run dual webers!
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Sam 29 Nov - 13:37
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Sam 29 Nov - 14:39
Very good job thumbsup thumbsup
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Sam 29 Nov - 14:42
Where will you find Webers carbs ?
I think that a turbo may be too fragile for intense off road racing scratch
Chromecop
Chromecop
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Sam 29 Nov - 16:58
You may have a good point about the turbo thumbsup
Weber carbs aren't that uncommon in scale and I do have quite a few in my parts box.
Chromecop
Chromecop
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Lun 8 Déc - 11:46
I made some progress last night. Still not sure if this Engine will be used as I have a Porsche Turbo Engine on it's way home. It was given to me from a kind fellow modeler in Belgium! Thanks Marc!!!!!
Chromecop
Chromecop
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Mar 9 Déc - 15:34
I've kept working on the Engine but also started building a rollbar;
Chromecop
Chromecop
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Dim 14 Déc - 18:35
Unfortunately the Porsche-Engine doesn't look as good in the rear as I'd hoped for, so I'll stick to the VW-Engine:
This looks much smoother and not as "Heavy" as the Porsche:
Also started the exhaustsystem this evening:
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Dim 14 Déc - 19:01
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Dim 14 Déc - 20:04
Great !
The Porsche engine was big indeed, but I have seen Beetles powered by big American V8s :
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Lun 22 Déc - 0:23
Great !
Je trouve un peu dommage de mettre un V8 dans un baja, on s'éloigne de l'idée de départ de la coccinelle et du moteur refroidis par air. Un flat 6 de Porsche ou de Corvair, ok. On voit même des moteurs SUBARU dans des VW.
Very good job on this baja, Chromecop aplause
Chromecop
Chromecop
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Mar 6 Jan - 20:40
Added more details to the bug this evening:
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Mar 6 Jan - 21:00
surpris thumbsup worthy
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Mar 6 Jan - 21:34
I like your project on this bug thumbsup thumbsup thumbsup
you are very crayzycut a gear box of this kit and glue another, it come from the meyer manx kit ?
Chromecop
Chromecop
MessageSujet: Re: 1957 Baja Bug Gunze/Kyosho kitbash (FINI)   Mar 6 Jan - 21:39
I really don't know what kit the gearbox comes from...I just found it in my parts-box. Could be the manx or the California Buggy from Revell ??? It looks pretty good though! oui
» 1957 Buick Caballero " DOROTHY " FINI
» hpi sandscorcher copy
» mon baja 5sc ss fini
» Piper J-3 Cub Airium de Kyosho
» prototype rc 57 cm3
