 VW Karmann Ghia by Gunze
Chromecop
Chromecop
VW Karmann Ghia by Gunze Empty
MessageSujet: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyVen 12 Oct - 12:32
Hi all !
Right now I've just finished a build of a Renault 5 in "lowrider-style" so I had to dig into my stash and find something to build after the R5's been completed. I Realized that I still haven't built a Ghia, so that's it then....A Ghia it'll be !
I had a few to choose from but decided to build one of my Gunze Ghias. I will also incorporate some parts from an old PMC Promo to update it and make "lowlight Ghia" (meaning a pre 1960
Ghia).
VW Karmann Ghia by Gunze 00412
VW Karmann Ghia by Gunze 00511
VW Karmann Ghia by Gunze 00612
The car itself will be built in a pretty modern way with 22" wheels and comfortable sports seats.
VW Karmann Ghia by Gunze 00012
VW Karmann Ghia by Gunze 00113
VW Karmann Ghia by Gunze 00311
That's it for now. Gotta finish my Renault before proceeding on this one, stay tuned....
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyVen 12 Oct - 21:24
I had never seen this PMC promo What a Face
Are you sure that you want to cut it up ? :peur1:
Chromecop
Chromecop
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyVen 12 Oct - 21:26
Yes, I'm sure..... Very Happy I have another one which is better and not so damaged. This one has a big crack all over it's roof bleme
Chromecop
Chromecop
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyVen 12 Oct - 21:29
I've done som more work to the Promo before cutting it apart:
VW Karmann Ghia by Gunze 00711
Chromecop
Chromecop
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyLun 15 Oct - 12:24
This morning I started doing the chassie and suspension. Also adding Pegasus 19" disc breaks to the modern wheels I'm using.
VW Karmann Ghia by Gunze 00911
The front axle/suspension has been modified and lowered.
VW Karmann Ghia by Gunze 00811
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyLun 15 Oct - 13:05
Good start !
Chromecop
Chromecop
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyMar 16 Oct - 20:15
Here's a few pics of the work I've done during the last 24h:
VW Karmann Ghia by Gunze 01011
VW Karmann Ghia by Gunze 01111
VW Karmann Ghia by Gunze 01211
VW Karmann Ghia by Gunze 01311
VW Karmann Ghia by Gunze 01411
Chromecop
Chromecop
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyJeu 18 Oct - 20:09
Modified the stock rear wheel hubs as well this evening so they can be incorporated with the new disc breaks.
VW Karmann Ghia by Gunze 01511
Chromecop
Chromecop
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyLun 22 Oct - 11:29
The new front has been glues to the body and I have also made new shocks both front and rear:
VW Karmann Ghia by Gunze 01811
VW Karmann Ghia by Gunze 01611
VW Karmann Ghia by Gunze 01711
Chromecop
Chromecop
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyMar 23 Oct - 22:58
Modifying the engine dummy and chassies plate to look better and accept the lowered rear suspension:
VW Karmann Ghia by Gunze 01911
VW Karmann Ghia by Gunze 02011
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyMer 24 Oct - 9:11
Great job! thumbsup
Chromecop
Chromecop
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyMer 24 Oct - 20:59
Oliv' a écrit:
Great job! thumbsup
Thanks! It'll take a lot of work to get the seams smooth and I also will have to scratchbuild the taillights as the ones on the Promo don't look good enough. siffle
Chromecop
Chromecop
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyJeu 25 Oct - 21:45
Worked almost 2 hours on my Ghia this morning before going to work:
VW Karmann Ghia by Gunze 02111
VW Karmann Ghia by Gunze 02211
VW Karmann Ghia by Gunze 02311
VW Karmann Ghia by Gunze 02411
VW Karmann Ghia by Gunze 02511
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyJeu 25 Oct - 22:20
Nice scratch!
En cours: VW Karmann Ghia by Gunze Mini_433542IMG20170803180818
Chromecop
Chromecop
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyJeu 25 Oct - 22:44
Rainbow warrior a écrit:
Nice scratch!
Thanks !!! santé!
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyJeu 25 Oct - 22:53
As usual with your projects, a lot of work worthy
Chromecop
Chromecop
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyMer 31 Oct - 17:35
Roof glued to body and both A-pillars repaired:
VW Karmann Ghia by Gunze 02611
Chromecop
Chromecop
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyMer 31 Oct - 20:19
Quite a lot of work to smoothen the joints where the roof meets the A-pillars:
VW Karmann Ghia by Gunze 02711
Chromecop
Chromecop
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyJeu 1 Nov - 20:20
Time to fill the recessed areas for the taillights as I will scratchbuild the new ones which will be correct for a "lowlight" Ghia.
VW Karmann Ghia by Gunze 02811
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyJeu 1 Nov - 20:38
Fine !
I have always found strange that Gunze made the roof in clear plastic epaule
Chromecop
Chromecop
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyJeu 1 Nov - 22:18
....I have always found strange that Gunze made the roof in clear plastic  epaule
Indeed, very strange. The Tamiya would be easier to build, but I kind of liked the idea to see if the Gunze Ghia really is buildable ? surpris
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptyVen 2 Nov - 10:20
Yes oui
I have one too, so I will follow your work with interest...
Chromecop
Chromecop
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptySam 3 Nov - 15:53
The recessed areas for the stock taillights have been filled and sanded to the right shape:
VW Karmann Ghia by Gunze 02911
I also had to add some material to the front valance as it wasn't "high" enough after the modifications:
VW Karmann Ghia by Gunze 03011
VW Karmann Ghia by Gunze 03111
Chromecop
Chromecop
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptySam 3 Nov - 22:39
Scratchbuilding new taillights now:
VW Karmann Ghia by Gunze 03211
Chromecop
Chromecop
MessageSujet: Re: VW Karmann Ghia by Gunze   VW Karmann Ghia by Gunze EmptySam 3 Nov - 23:54
First taillight done and testmounted:
VW Karmann Ghia by Gunze 03311
VW Karmann Ghia by Gunze 03411
