 Jantes et pneus XXL
Jantes et pneus XXL Empty
MessageSujet: Jantes et pneus XXL   Jantes et pneus XXL EmptyLun 2 Sep 2013 - 8:55
Un tuto trouvé sur un forum US, je vous laisse traduire!!! 😇
Citation :
I was often asked what kind of tires I have on my models.
I have already said a few times, but found it better, I simply make a new Thread about it.
These are a few original TD Groovy graders tyres which I still have:
Jantes et pneus XXL Rubbers022
An example:
http://www.showrods.com/gallery_pages/groovy_grader3.html
Over the years, i collected some of unused kit-tires.
Jantes et pneus XXL Rubbers020
These are, for example, the tires from Bad Medicine and Ice T kits.
I make from these three parts a wider version:
Jantes et pneus XXL Rubbers015
I glue them together and sand the surface:
Jantes et pneus XXL Rubbers016
The Result:
Jantes et pneus XXL Rubbers017
Jantes et pneus XXL Rubbers019
More tip`s:
I use for the rear tyres, for my Showrods, also slicks from older Formula 1 kits on a scale of 1:20. (Prefers late 70`s)
Here are a few:
Jantes et pneus XXL Rubbers003-1
Jantes et pneus XXL Rubbers004-1
Jantes et pneus XXL Rubbers005-1
Jantes et pneus XXL Rubbers006
These packages (on a scale of 1:20) are available at Tamya:
Jantes et pneus XXL Rubbers007
They come in different diameters and widths (depending on the vintage and regulations):
Jantes et pneus XXL Rubbers010-1
Jantes et pneus XXL Rubbers009
The results:
Jantes et pneus XXL Modelle031
Jantes et pneus XXL 038
Jantes et pneus XXL Modelle041
Jantes et pneus XXL GenuinIron020
Jantes et pneus XXL Show025
Jantes et pneus XXL Modelle1001
The next one, is not a very simple version. :Smile
Condition is a lathe and the necessary materials and tools. But if you have these, there are almost no limits. :o
Well, only time, high costs and effort... :Smile Wink
These are "rubber springs". We need them as low-holder for punching:
Jantes et pneus XXL Rubbers002
It gives different colors and many diameters and lengthen.The idea was good ;D, but the treatment exhibits problems. :Smile
The color of this rubber spring shows optically their hardens. The black is the softest (approx. 70 shores). :P
Thus one can turn it only in a device with very sharp tools, or work on it with rough sandpaper. I had to use both variants and after much work and sweat Wink, look this now in such a way:
Jantes et pneus XXL WineWagon048
These are aluminum tubes:
Jantes et pneus XXL Rubbers001
Jantes et pneus XXL WineWagon046
At the back of the new aluminum rims I turned a larger recess, in order to press the rims in. I receive after polish a stepless transition in the rim wall. And a very deep rim! ;D ;D ;D
Jantes et pneus XXL WineWagon047
Here is an example of the parts:
Jantes et pneus XXL Rubbers012
These are a few that I have produced:
Jantes et pneus XXL Rubbers011
On the left side are mine, on the right side, the original TD-GG `s:
Jantes et pneus XXL Rubbers024
Jantes et pneus XXL Rubbers025
This is also a cheap and fast version: different bottle tops and closures.
This can be seen in countless forms and diameters.
Stick two lids together. Drill a hole. Painting. Put the Rim in. Done. Wink;D ;D ;D
New ones:
Jantes et pneus XXL Fotos022
Incidentally, these were not expensive, but I've ordered it and waited six months until they were delivered... :Smile
Well, they are deep but not deep enough. ;D
My new, deeper, from aluminum.
Jantes et pneus XXL 04160005
I like to go new ways to get better methods, to find new materials and manufacture so cheaper my tires.
Here I have tried to make it from a piece of a hose.
The important thing is, the hose should be made of rubber and may have no lichen or wall reinforcement.
Jantes et pneus XXL 04160002
This hose has the name Perbunan®️, is not very expensive and is easy to edit.
http://techcenter.lanxess.com/trp/emea/en/products/description/article.jsp?docId=4030
The inner tube diameter is chosen so, that it no longer needs to be processed.
But he should be about one millimeter smaller than the outside diameter of the rim, for a better hold.
Jantes et pneus XXL Fotos014
Jantes et pneus XXL Fotos013
Jantes et pneus XXL Fotos017
Jantes et pneus XXL Fotos016
Jantes et pneus XXL Fotos018
My newest method:
These rubbers are of a handlebar grip for bicycles.
Jantes et pneus XXL 001
With a little editing and mounted on my homemade wheels, the whole thing looks like this:
Jantes et pneus XXL 005
Jantes et pneus XXL 017
Keep only the eyes open and you will certainly find more possibilities! Wink;D ;D ;D
MessageSujet: Re: Jantes et pneus XXL   Jantes et pneus XXL EmptyMer 4 Sep 2013 - 15:42
Voici la traduction faite gentillement par Mrbigblock👍
Merci à toi
Je laisse la traduction comme ça pour l'instant et je referais le poste comme il faut plus tard!!!mrgreen
"On me demande souvent quels pneus je monte sur mes modèles. J’en ai déjà parlé à plusieurs reprises mais le plus simple c’est d’ouvrir un post à ce sujet.
Voici quelques pneus du kit Tom Daniel Groovy Grader que je possède :
Photo 1
Un exemple :
Depuis longtemps, je conserve les pneus inutilisés des kits que je monte.
Photo 2
Voici par exemple les pneus des Kits « Bad medecine » et « Ice T »
Et voici comment, à partir de ces 3 parties de pneus, comment en faire un plus large :
Photo 3
Les coller ensemble et poncer la surface :
Photo 4
Voici le résultat :
Photo 5 à 6
Encore quelques astuces :
J’utilise, pour les pneus arrière de mes Showrods, des slicks récupérés sur des kits de formules 1 au 1/20 (plutôt celles des années 70)
En voici quelques uns :
Photo 7 à 10
Ces packs au 1/20 sont disponibles chez Tamiya :
Photo 11
Ils peuvent être de différentes largeurs et différents diamètres (en fonction de l’époque et des séries) :
Photo 12 à 13
Voici ce que ca donne :
Photo 14 à 19
Pour le prochain exemple, ca se complique un peu. Il vous faut posséder un tour ainsi que les outils et la matière première. Mais si vous avez ceci, il n’y a quasiment pas de limite, sauf le temps et l’argent qu’il faudra y investir.
Ceux-ci sont des morceaux de ressorts en caoutchouc :
Photo 20
Ils sont disponibles en plusieurs couleurs, longueurs er diamètres. L’idée est bonne mais la réalisation révèle quelques difficultés :
La couleur du ressort en caoutchouc est fonction de sa dureté. Les noirs sont les plus souples. Vous pouvez soit les tourner avec des outils bien affutés ou utiliser du papier de verre à gros grain. J’ai utilisé ici les deux techniques et avec beaucoup de travail et de sueur voici ce que ca donne :
Photo 21
Voici des tubes en aluminium :
Photo 22 à 23
A l’un des extremités de la nouvelle jante, j’ai réalisé un évidement pour pouvoir y entrer en force la jante plastique. Après polissage, la jante plastique vient affleurer la partie intérieure de la jante en aluminium, la transition est quasi invisible. On obtient une jante très profonde !
Photo 24
Voici un exemple des différentes parties de la jante :
Photo 25
Voila quelques jantes de ma fabrication :
Photo 26 à 27
Sur la gauche, la mienne, sur la droite, celle du kit du Tom Daniel Groovy Grader :
Photo 28 à 29
On peut aussi réaliser des jantes bon marché avec des bouchons et des capuchons :
Photo 30
La variété des tailles et des formes est infinie :
Photo 31
Collez 2 bouchons ensemble, percez un trou au centre, peignez, insérez la jante plastique et c’est terminé !
Un nouveau modèle :
Photo 32
Etrangement, ce modèle n’est pas très cher, mais j’ai presque attendu 6 mois avant de recevoir ma commande. Ces jantes sont profondes mais pas assez à mon goût ! Donc voici une adaptation encore plus large en aluminium.
Photo 33
J’aime explorer pleins de pistes pour améliorer mes techniques, dénicher de nouveau matériaux et fabriquer des pneus toujours moins chers. J’ai tenté d’en faire en utilisant une section de durite. Le plus important dans le choix de la durite ; qu’elle soit en caoutchouc et qu’elle ne comporte pas de renforts ni d’inscription.
Photo 34
Cette durite est de marque Perbunan ®️, elle est bon marché et facile à se procurer.
Il est possible de choisir le diamètre intérieur du tube, il n’y a donc pas nécessité de l’usiner. Il convient de prendre une durite d’un diamètre intérieur inférieur d’1mm au diamètre extérieur de la jante plastique afin que celle-ci entre en force et soit correctement maintenue en place.
Photo 35 à 39
Je vous présente ma dernière méthode en date. Ces pneus sont faits à partir de poignées de vélo :
Photo 40
Une fois travaillés et montés sur des jantes maison, ca donne ca :
Photo 41 à 42
Gardez les yeux ouverts et vous trouverez certainement de nouvelles idées !
MessageSujet: Re: Jantes et pneus XXL   Jantes et pneus XXL EmptyMer 4 Sep 2013 - 17:41
Que dire de plus..et les poignées de bécanes...!!! worthy worthy worthy worthy
MessageSujet: Re: Jantes et pneus XXL   Jantes et pneus XXL EmptyMer 4 Sep 2013 - 21:08
excellent thumbsup
MessageSujet: Re: Jantes et pneus XXL   Jantes et pneus XXL EmptyMer 4 Sep 2013 - 21:18
J'adore les tubes en alu tournés avec les jantes dedans c'est terrible. Par contre je saisis mal comment il utilise les bouchons, et il explique peu...
Elvishad38
Elvishad38
MessageSujet: Re: Jantes et pneus XXL   Jantes et pneus XXL EmptyVen 6 Sep 2013 - 18:33
excellent les fabrication bravo
Jantes et pneus XXL S7-l-a11
transfo
transfo
MessageSujet: Re: Jantes et pneus XXL   Jantes et pneus XXL EmptySam 21 Sep 2013 - 19:46
Il faut du matos pour le faire.
Entre autre un tour.
Un collègue tourneur m'en a fait, mais pas encore essayé sur une réa.
Jantes et pneus XXL
